Activity Forums Maxon Cinema 4D Spline dynamics + constraints = lag
  • Spline dynamics + constraints = lag
    Posted by Justin Crowell on April 24, 2019 at 2:52 am
    SOLVED: It WAS a priority issue. I had to change it to generator and change the number to something other than zero.
    Hi all,
    I’m trying to attach two ends of a spline to two nulls that are being moved (using joints). I’m using constrains and spline dynamics.
    I guess it’s somewhat quick movement, and one end of the spline pretty quickly comes away from its constraint point (which is a null). I get the dreaded red line.
    I thing I’ve played with every parameter that I can think of, but nothing seems to help it stay more tightly attached. Am I missing something?
    Justin Crowell replied 7 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
