Activity Forums Maxon Cinema 4D Spline Coordinates Issue
  • Spline Coordinates Issue
    Posted by Jack Monkiewicz on August 23, 2011 at 2:52 am
    Hi there,
    Could someone please tell me why the Coordinates manager wont let me change or adjust values of splines?
    I am trying to zero the z axis of a spline path and every time i adjust it, the value reverts back to the original path.
    I am a C4D beginner so its all a bit hard at the moment.
    Jack Monkiewicz replied 15 years ago 2 Members · 4 Replies
  • Adam Trachtenberg
    August 23, 2011 at 4:19 am
    It should work as long as you click the Apply button after the change. Or unless you have keyframes on the splines position.
    Also, if it’s a primitive spline and you’re just trying to move the axis (not the spline) — you can’t do that. You would have to make it editable first.
  • Jack Monkiewicz
    August 23, 2011 at 10:45 am
    Hi Adam,
    the spline is just a bezier spline on a picture i traced. Not sure if thats a primitive spline or not? the position points aren’t keyframed.
  • Adam Trachtenberg
    August 23, 2011 at 2:46 pm
    That’s strange. I have no problem moving spline points with the coord manager here. Are you suuure you don’t have KFs on it? Didn’t maybe have autokey turned on?
  • Jack Monkiewicz
    August 24, 2011 at 11:03 am
    Hi adam, automatic keyframe isn’t highlighted, so i assume its not active.
