Activity Forums Adobe After Effects Spirograph in 3D
  • Brian Charles
    June 30, 2014 at 6:08 pm
    Since Write-On uses 2D coordinates, I’m pretty sure that the expression needs to be applied to a particle system with 3D coordinates to make a 3D animation.
    In the linked file I created a null named Null: Center as in the script, then I applied the script to the Null’s position property, finally I linked Write-On’s brush position for a 2D Spirograph and Particular’s positions for a 3D one.
    7695_spiro.aep.zip
    The only other way might be to generate the animation in 2D and then wrap it around a sphere using CC Sphere, really pseudo-3D.
  • Don Johnson
    July 1, 2014 at 12:24 am
    Thanks Brian,
    Unfortunately I am running CS 5.5 so am unable to open your example. I have recreated my own with the position of Trapcode Particular parented to a null, with the expression copied into the nulls position. The look I am getting is not as per the example, it still appears to operate only in a 2D space.
    File attached
    7697_spirographattempt.aep.zip
  • Brian Charles
    July 1, 2014 at 1:00 am
    I just looked at yours and its is 3D, add a camera and rotate it.
    See this:
    7700_spirocopycs5.5.aep.zip
  • Don Johnson
    July 1, 2014 at 1:29 am
    Ah! Thankyou!
