Activity › Forums › Adobe After Effects › Spiral expression + camera
  • Spiral expression + camera
    Posted by Peo Fogelstrom on January 1, 2016 at 11:11 pm
    Hiya,
    Having some issues with a premade expression for a spiral as seen below;
    shrink=time+1
    radius=1000
    angle=time*10
    x=radius*Math.cos(degreesToRadians(angle))
    y=radius*Math.sin(degreesToRadians(angle))
    //z=0 // no depth
    z=time*10 // with depth
    centre=[640,360,0]
    add(centre,[x,y,z])
    I want to use the spiral for my motion path for the camera. Everything works fine in it’s own comp when trying it out but if I create a new light in my main comp with the expression the light/emitter is going off-track from the spiral as seen below;
    https://imgur.com/Sc51CfN
    Anyone?
    View post on imgur.com
    Kalleheikki Kannisto replied 10 years, 8 months ago 2 Members · 6 Replies
  • Kalleheikki Kannisto
    January 2, 2016 at 8:47 am
    By itself it should work just fine. What other layers do you have in the comp? Are some of them precomped?
  • Peo Fogelstrom
    January 2, 2016 at 9:02 am
    https://imgur.com/QSyN6mD
    These are all the layers.
    Pre-comp layers contain images with their own adjustment layers and Holomatrix effect, nothing more.
    I guess I also could make a circular mask, make a Null to follow path and pair camera to it’s position for X+Z and increase Y over time to get about the same result.
    January 2, 2016 at 4:52 pm
    Yeah, I don’t see any reason it wouldn’t work. Does it make any difference if you turn off all other layers but the emitter (light), camera and particular? I made a comp like that and particular was correctly following the light.
  • Peo Fogelstrom
    January 2, 2016 at 6:46 pm
    No difference.
    However I copied everything from my Main comp over to the test-comp for the spiral for expression-edition visualisation and the light/emitter moves fine. Guess I’ll just continue my work in that comp instead then.
  • Peo Fogelstrom
    January 2, 2016 at 8:00 pm
    Found out what caused it to go off-track. Got a world transformation of 90 degress on X on particular set up to get the spiral actually going upwards.
    How would I go about correcting this? Might be useful to know in the future as well but for now I could turn everything else 90 degrees.
    January 3, 2016 at 4:11 pm
    Ok, that would certainly cause this issue.
    Two ways to avoid the problem:
    1) Switch the y and z in the expression so that you get the motion along the correct axis or
    2) Rotate the camera 90 degrees around the point of interest instead of the Particular World
