Activity Forums Apple Final Cut Pro Legacy Spinning Pinwheel Every Time I Switch Applications Back to FCP7?
  • Spinning Pinwheel Every Time I Switch Applications Back to FCP7?
    Posted by Stephen Metzger on July 9, 2015 at 6:46 pm
    I’m editing a project on FCP7, and every time I switch back to FCP from any other application, I get a stopwatch for a few seconds and then a spinning pinwheel for about 10 seconds.
    Does anyone know why this would be happening and if there’s something I can do about it?
    I’m on an early 2013 MacBook Pro running OS X Yosemite and editing with a USB 3.0 drive using mainly DVCPRO HD footage (lots of it.). Never had this problem with other projects.
    Thanks.
    Tom Matthies replied 11 years, 2 months ago 3 Members · 2 Replies
  • Shane Ross
    July 9, 2015 at 7:12 pm
    [Stephen Metzger] “I’m on an early 2013 MacBook Pro running OS X Yosemite”
    That’s why. FCP 7 isn’t supported under Yosemite. Full support for FCP 7 stopped at 10.8…actually, I think before that. 10.7 was in play when FCP 7 was discontinued, and no longer supported by Apple. OS 10.8 worked fine…but really, from that point on they didn’t take FCP 7 compatibility into consideration when making later OS versions.
    Shane
    Little Frog Post
  • Tom Matthies
    July 9, 2015 at 8:16 pm
    You might check your Power preferences and make sure that your external drive isn’t spinning down or going to sleep while you are using a different application. It sounds like FCP might be waiting for the drive to spin back up before it responds.
    Not my monkeys. Not my circus.
