Activity Forums Apple Final Cut Pro Legacy Spinning Newspaper into Frame_Old Newsclip Effect
  • Spinning Newspaper into Frame_Old Newsclip Effect
    Posted by Sherwood Ball on July 1, 2006 at 8:05 pm
    1) Can anyone give me a tip on how to achieve this spinning headline into
    frame effect from old theater newsclips?
    I try the rotation keyframed, along with scale, AND anchor but
    it still spins off kilter/whacky.
    2) Also frame by frame keying is so tedious – any time saving workaround?
    HELP!
    Kevin Monahan replied 20 years, 2 months ago 4 Members · 3 Replies
  • Chris Poisson
    July 1, 2006 at 8:35 pm
    SE,
    This is really easy, if you have your anchor point right in the center of the part you want to spin on. Keep tweaking that until it spins the way you want. I’ve done this effect many times in FCP, but it is easier in AE.
    Have a wonderful day.
  • Steve Eisen
    July 1, 2006 at 9:15 pm
    you might want to try the Multi Spin effect under Slide. Change the default from 3 to 1.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Kevin Monahan
    July 2, 2006 at 3:25 am
    A bit of motion blur sells the effect. I’d do this in Motion.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
