Activity › Forums › Adobe After Effects › Spinning Logo Problem
  • Spinning Logo Problem
    Posted by Nadaav Zohar on November 10, 2008 at 9:40 pm
    This hasn’t been an issue before, but for some reason when I tried to make a spinning logo today, the side texture would only wrap around the periphery of the transparent field on my graphic, rather than around the irregular edges of the logo itself.
    I tried rebuilding the graphic in Photoshop and then importing it again, with no luck.
    As usual, I’m using a tweaked version of the “shatter” effect to do the spinning motion.
    Is there a setting I should check, or is it possible that the problem originated in Photoshop?
    Nadaav Zohar replied 17 years, 10 months ago 2 Members · 2 Replies
  • David Bogie
    November 10, 2008 at 9:54 pm
    [Nadaav Zohar] “As usual, I’m using a tweaked version of the “shatter” effect to do the spinning motion. “
    You must bring the custom shatter Map into Shatter in order to be able to extrude the piece. You do not not indicate you have done that properly.
    bogiesan
  • Nadaav Zohar
    November 11, 2008 at 1:12 am
    Thanks for replying!
    My shatter map is set to “custom,” and it matches the file name of the background image. Nevertheless, I’ll double-check next time I’m at work.
