Activity › Forums › Adobe After Effects › Spinning car wheels
  • John Cuevas
    June 2, 2016 at 4:09 pm
    You are going to need to replace the tires and create your own, preferably much larger, then use those in your final comp with 3D enabled. Something along the lines of this.
    10147_cartirefolder.zip
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Wisza Czarny
    June 2, 2016 at 9:01 pm
    I have no idea how to thank You for the solution. I tried it this way, but something was always wrong. You’re the man 🙂 THANKS A LOT
