Activity Forums Apple Final Cut Pro Legacy Spinning Beach Ball
  • Spinning Beach Ball
    Posted by Stephensf on November 19, 2007 at 1:45 pm
    I have just installed a second hard drive and whenever I run a sequence I get an obligatory 30 second wait with beach ball before it runs the timeline.
    This also happens intermittently while the sequence is playing. It will be playing, stop for 30-60 seconds with the ball spinning, and then carry on.
    Any ideas appreciated.
    Steven Lambion replied 18 years, 9 months ago 4 Members · 6 Replies
  • 13 Create COW Profile Image
    13
    November 19, 2007 at 7:43 pm
    More info is needed!
    Connection of the drive?
    Format of the drive?
  • Stephensf
    November 19, 2007 at 8:50 pm
    Ok, I got this info from the Disk utility
    File system: Mac OS Extended (Journaled)
    Connection Bus : ATA
    Partition Type: Apple_HFS
    Device Tree: sata/k2-sata@1/@0:3
    I’m not that techy about hard drives. Any help appreciated.
  • Steven Lambion
    November 21, 2007 at 1:48 am
    It sounds like your HD might be going to sleep. Go into System Preferences, then Energy Saver. At the bottom, you should see a check box called “Put the hard disk(s) to sleep when possible”. This is on by default, check it off.
    Another thing you might want to look at, is the speed of the hard drive. 7200 rpm is a good speed for video editing. If your working with HD try to get a 10000rpm.
    Hope this helps!!
    Video Specialist
    Apple Developer
    Owner of GranitWorks
  • Stephensf
    November 23, 2007 at 11:32 am
    That seems to have fixed it. Thanks.
  • Mark Barroso
    November 26, 2007 at 6:18 pm
    That’s no beach ball. It’s the Wheel of Death.
  • Steven Lambion
    December 5, 2007 at 4:43 am
    Actually that’s the loop cursor used when the active process is in a loop(When nothing else can be done in the application), similar to Apple’s old Clock cursor. The spinning beach ball was to replace the Clock in OS X, it came from NeXTStep, the OS that evolved into OS X.
    Video Specialist
    Apple Developer
