Activity › Forums › Avid Media Composer › Spinning beach ball after insert when returning to sequence
  • Spinning beach ball after insert when returning to sequence
    Posted by Ali Grossman on July 4, 2012 at 6:16 pm
    I am editing AVID MediaComposer on a MacBook Pro with LaCie thunderbolt drive. I was editing on 6.0 but a few days ago, I encountered a problem that every time I placed an edit in the sequence, or trimmed, a beach ball would appear when I tried to play my sequence to review my edits. This :20 delay is driving me crazy. I upgraded to 6.0.1.1 last night but the problem still exists. I also transcoded my sequenece to the HD, thinking that it might speed up the project. Nope. Any ideas? I would love to enjoy the 4th of July, but instead I am watching beachballs on my laptop.
    Ali
    Michael Phillips replied 14 years, 2 months ago 2 Members · 5 Replies
  • Michael Phillips
    July 4, 2012 at 6:37 pm
    Try cutting that entire sequence into another sequence just for a test. Perhaps there is something “funky” with the one you’re working on.
    Also, does the beachball appear everytime regardless of where the edit is made (first half of sequence, second half, etc.) as there may be a corrupt file in the sequence somewhere.
    Michael
    Michael Phillips
  • Ali Grossman
    July 4, 2012 at 7:50 pm
    split the sequence into two parts and, sure enough, one sequence has the beach ball and the other does not. consolidating the “bad sequence” into new media and hoping that works. will let you know!
  • Michael Phillips
    July 4, 2012 at 8:44 pm
    Yeah, kinda sounded like there was a corrupt clip in there or perhaps it is AMA linked to longer clips. I find the beach ball on AMA to H.264 clips longer than 20 minutes to be brutal.
    Michael
    Michael Phillips
  • Ali Grossman
    July 5, 2012 at 4:54 am
    Yes, this was a transported clip (partitioned because of length) from a JVC mpg4 file. Darn it. I tried transcoding to a different drive but still the same problems. I am finding that most of my long clips are responding in a similar fashion, especially when I am working in group clips/multicamera mode. I wonder if it is part clip/part computer or AVID issue. If anything else comes to mind, please give me a shout out.
  • Michael Phillips
    July 5, 2012 at 5:34 am
    Yes… AMA and multicamera are a no-no. There “might” be a chance of success if the codec used is native to Avid.
    Are you transcoding the AMA linked clip at the master clip level? You may need to subclip first and transcode the subclips as I’ve had problems with transcode on longer clips as well.
    Michael
    Michael Phillips
