Activity › Forums › Adobe After Effects › spinning around a null stay oriented up
Posted by Jason Brown on July 29, 2011 at 2:28 pmI feel like I’ve done this before, but I’m completely blanking…I feel like I may have even asked this question before, so I’m sorry if I’m repeating myself! 🙂
I have 5 layers in a circle design that need to stay upright as they spin around a null. No 3D, very simple…at least it should be 🙂
Jason Brown replied 15 years, 1 month ago 2 Members · 5 Replies -
Walter Soyka
July 29, 2011 at 2:39 pmUse an expression to set their rotation to the inverse of the rotation of the null:
-thisComp.layer("Null 1").transform.rotationThis tells each of the children to rotate in the opposite direction the parent is rotating (at the exact same rate). The two rotations will counteract each other, and the children will remain upright.
You will want to make sure that the children’s anchor points are centered — otherwise you will get some bizarre but (possibly very cool) spirographic motion.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Jason Brown
July 29, 2011 at 2:49 pmThanks walter, but all this does is rotate the objects in the opposite direction that the null spins. If I parent the layers to the null they are expressed to, they just stay still…
not quite there…
Jason Brown
July 29, 2011 at 2:52 pmI forgot I had changed the anchor point…nevermind. THANK YOU for your help!
Walter Soyka
July 29, 2011 at 3:04 pm[Jason Brown] “I forgot I had changed the anchor point”
That’s critical — the idea is that the individual objects must rotate about their own centers contrary to the global rotation.
[Jason Brown] “THANK YOU for your help!”
You’re welcome!
Walter Soyka
Jason Brown
July 29, 2011 at 3:10 pmI knew I had done this awhile ago…so I did a search
https://forums.creativecow.net/thread/2/988902#988902
You and Roland were both very helpful…I just don’t work in AFX enough…or with expressions, I only do it every once in awhile. That is why I love the COW!! And helpful people like yourself…
Thanks again!
