Spinning an object on an axis without it moving from its center position
Hi hi. I have looked for this but I can’t seem to figure it out still. I created a coin by stacking many layerss, precomposed it and and am now attempting to have it spin on its Y axis. It works. However, as it spins, it moves right and left along the X axis instead of staying in one position while spinning. I can’t tell if this is because of how it was created or what. Something that should be so simple is becoming a major headache. Any ideas? I’ve tried spinning it 1x on Transform > Y Rotation, I’ve tried setting anchor points (doesn’t stay), I’ve tried manually positioning it (looks choppy). This is the tutorial I used to create and spin it: https://youtu.be/Rcq3uq2WNsI — You can see even his logo is moving a little to the left on each spin but mine is much more obvious. Is it inevitable? Appreciate any help, ty!
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
