Activity › Forums › Apple Motion › spinning 3d object.
spinning 3d object.
Posted by Jack Tilling on March 19, 2015 at 12:00 pmHi I have a spinning 3D Logo. I want to have the logo so that when it spins around it doesn’t change to backwards. Im sure this is possible somehow but I am pretty novice with using Motion 5. Can anyone help me (and put it in simple terms)
thanks in advance!John Rofrano replied 11 years, 6 months ago 4 Members · 7 Replies -
Robin S. kurz
March 20, 2015 at 9:32 amHow exactly are you getting a 3D logo in Motion? Motion has no 3D capabilities. Or are we talking about a CLIP of a spinning logo? mObject?
Either way, the only way would be to loop the spin the moment the object is at a right angle to the screen, which seems obvious. No idea what else you could do. Depending on how exactly you’re getting this “3D”, how fast it’s spinning, what the logo looks like etc. etc. etc. it will likely be a tedious and inelegant solution either way.
– RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich! -
Jack Tilling
March 20, 2015 at 11:16 amthanks. I created a 3D Object by taking a logo (jpg) and importing it into motion. From there a used a replicator with 1 row and 1 column and set the depth to about 50 with 100 ranks. I then put a ‘Spin’ behaviour on the object.
I have now figured out the way to get the object to be the same both sides. I duplicated the replicator but set one of the cell control allignments to 180 Degrees. This way there is effectivly 2 objects both spinning in the same space at the same time but one is 180 degrees out from the other. Seems to work pretty well other than it slowing my Mac down a load as it struggles to render it. All fine when exported as a movie how ever. im sure there is a better way of doing this but in the hour of need it seemed to work! 🙂
Id still like to know what anyone else would do how ever so please keep posting! -
Bret Williams
March 20, 2015 at 12:00 pmThe logo could be mObject or extruded via a replicator. Either can be manipulated within motion and interact correctly with other layers and lights.
Robin S. kurz
March 20, 2015 at 3:17 pmDepending on the Logo, I’d most likely use mObject. Have never been much of a fan of the “replicator trick”. But if it works for you… 🙂
– RK
Bret Williams
March 20, 2015 at 4:04 pmThe replicator trick can be pretty amazing in the hands of folks like motionvfx and others. Even AE folks rarely use extrusion because of the horrible render times. mObject is great if you’ve got it. And right now they’ve dropped the price and it’s on sale. If you use motion, I’d get it.
AE doesn’t even have replicator, but check out this template from ironykdesign https://videohive.net/item/broadcast-design-complete-news-package-5/6058779
We used it for a series of news videos. All the chrome extruded text is nothing but repeated layers in 3D space. They have specific outlines and a specific front layer to get the effect. The beveled glass with it’s refractions is amazing too, but the way it’s done has to do with empty nested comp layers. Not sure if it would work in motion. It’s almost a fluke of the way AE is designed.
Robin S. kurz
March 20, 2015 at 5:06 pm[Bret Williams] “And right now they’ve dropped the price and it’s on sale. If you use motion, I’d get it.”
Mind you, not only have they dropped the price of everything to ridiculously low prices, they are even having a 30% off of everything sale for another week, yes… so that’s even 30% MORE off of the aforementioned ridiculously low prices. The pro bundle at $100 is a complete no-brainer imho.
And the handling from within the mObject app is realtime, even with some of the most complex objects. AND you can add drop zines and more at your leisure.
So if Motion/FCP X and 3D is your thing, this is the plugin/app you want to get.
– RK
John Rofrano
March 28, 2015 at 9:04 pmYou might also want to look into Boris Continuum Complete Extruded EPS. It’s awesome for extruding customer’s logos. Here is a two part tutorial that I did for Boris TV that does exactly what you are looking for using BCC Extruded EPS:
https://www.youtube.com/watch?v=JY6bcTK_xhY
https://www.youtube.com/watch?v=HmEyogfWLwAAll of this was done in FCP X but you can use it in Motion as well if you want.
~jr
http://www.johnrofrano.com
http://www.vasst.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
