Activity › Forums › Apple Final Cut Pro Legacy › Spinback 3D issue
  • Spinback 3D issue
    Posted by Dennis Leppell on June 5, 2009 at 3:44 pm
    I’ve never noticed this before, but then I really never use this transition. I’m dropping the Spinback 3D b/w two pieces of text, and instead of spinning on the center axis, the text shifts to the left as it spins out of existance…and the incoming text does the same, shifted to the left as it spins in, to settle into place in the correct spot. I want text 1 to spin on the center axis with no move left or right….multiple spins would be great, but probably need to head to motion for that. The piece is finished and approved as is, but this is really annoying me.
    manually keyframing with Basic 3d has the same results.
    Thoughts or suggestions?
    Dennis Leppell replied 17 years, 3 months ago 4 Members · 4 Replies
  • Jason Diebler
    June 5, 2009 at 3:52 pm
    Maybe try a Cube Spin instead?
  • Steve Eisen
    June 5, 2009 at 5:01 pm
    Spinback 3D is not a transition for text.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Andy Mees
    June 6, 2009 at 8:15 am
    Dennis
    This is due to issues of parallel projection and Apple’s predefined 30° angle of view setting in the Spinback3D transition code. You just need to set this to an alternate value to achieve the effect you’re looking for … you can right click the Spinback3D transition and choose Open in Editor, then look for the code line angleofview = 30; and change it to angleofview = 0.0001; … then change the second line from top where it says transition “Spinback3D” to transition “My Spinback3D” … now, from the FxBuilder window choose Create Plugin… and save it to your Desktop. Finally, drop the new plugin into your /Library/Application Support/Final Cut Pro System Support/Plugins folder and then restart FCP. Your new plug should work as you want it to.
    You could also just download and install my free “Andy’s Flipper” plugin from my web page which is a simple hack of the Spinback3D plugin and includes a perspective control, multiple spins and the (default) option to spin through rather than spin back
    https://web.me.com/andymees
    Cheers
    Andy
  • Dennis Leppell
    June 9, 2009 at 6:42 pm
    Thanks Andy! i sent the project out as is, but that was exactly the type of explantation I was looking for. Off to check your site now….
