Activity › Forums › Apple Motion › spin text along vertical axis.
  • spin text along vertical axis.
    Posted by Boohoo on November 16, 2006 at 12:19 am
    Hi. New to this.
    Is it possible to animate text, for example, spin text, along the vertical axis? Are there x y z coordinates like in AfterEffects?
    Thanks in advance
    Adam Wilder replied 19 years, 10 months ago 3 Members · 4 Replies
  • Jim Kanter
    November 16, 2006 at 12:50 am
    The trick is to scale it on the X-axis only. Keyframe from 100% to -100% and back. Leave the Y axis values alone.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Boohoo
    November 16, 2006 at 5:34 pm
    Thanks for the reply. My apologies if this seems mundane…but how do I tweek the x,y values, can’t seem to find these variables. Thanks in advance. Is there a simple tutorial you could lead me to?
  • Jim Kanter
    November 17, 2006 at 2:11 am
    Select the text object, press the F1 key to open Properties in the Inspector, and twirl open the Scale parameter to see the x and y coordinates and keyframe the x scale separately.
    Jim Kanter,
  • Adam Wilder
    November 18, 2006 at 8:44 am
    Why not just use the Basic 3D filter in the Distortion section? While still faking 3D it allows you to control XYZ/HBP rotation. It also allows for you to add a back face input.
