Activity › Forums › Maxon Cinema 4D › Spherify – Falloff Tab?
  • Spherify – Falloff Tab?
    Posted by Evelyn Wandernoth on April 1, 2019 at 6:30 pm
    Hi, I’m a bit confused.
    I’m attempting to follow a tutorial to learn Cinema 4D, but I’m stuck at a step because my falloff tab with the Spherify effect does not have the same options as the one in the tutorial.
    This is the one from the tutorial:
    and this is mine:
    Can someone help me please? Not sure what to do.
    Evelyn Wandernoth replied 7 years, 6 months ago 2 Members · 2 Replies
  • Brian Jones
    April 1, 2019 at 7:08 pm
    all Falloff in C4D 20 is done with Fields (basically a movable separate object for the falloff), you would want to put in a Spherical field to follow the tutorial.
    Here is the simplest intro to fields I’ve seen so far https://lesterbanks.com/2018/09/c4d-r-20-fields-introduction/
    this one seems pretty good too https://www.youtube.com/watch?v=Vzt4midvx30
    but there are many more out there.
  • Evelyn Wandernoth
    April 1, 2019 at 7:25 pm
    Quite confusing at first but I seem to have gotten the hang of it pretty quick and got the desired effect! Thank you so much! Was looking for an explainer video but clearly wasn’t looking in the right place lmao
