Activity Forums Maxon Cinema 4D Sphere texture join problem
  • Sphere texture join problem
    Posted by Neil Harris on May 8, 2006 at 11:04 am
    Hello, I am pretty new to C4D and have made a sphere and applied a quicktime movie of a globe texture to it – All
    works fine apart from the seam/join is showing round the back. It is a simplistic ‘graphic’ representation of a map with
    a flat blue as the sea but there is a light line where the texture joins.
    Has anyone solved a similar problem?
    Any help greatly appreciated
    Brian Jones replied 20 years, 4 months ago 2 Members · 1 Reply
  • Brian Jones
    May 8, 2006 at 6:13 pm
    Unless the texture is seamless itself I think you can only set the texture to Tile some even number of times and check off Seamless in the Texture AM.
