Activity Forums Maxon Cinema 4D Sphere detail
  • Sphere detail
    Posted by Jack Sewell on August 7, 2010 at 4:13 pm
    I’ve seen a technique used in the Cinebench CPU test that I really like. You can access the project file as the gorilla talks about here:
    https://greyscalegorilla.com/blog/2010/08/secret-cinebench-scene-files/
    There’s a sphere on the right which has a pattern etched into it. The object is a polygon object with a sphere inside. The inside sphere giving a different texture to the outside texture so that the etching has more impact. I was looking for some sort of texture mapping to create the effect but can’t find any. DOes anyone know how this effect is created.
    Any suggestions would be great! 🙂
    many thanks,
    Jack
    Jack Sewell replied 16 years ago 2 Members · 5 Replies
  • Adam Trachtenberg
    August 8, 2010 at 4:02 pm
    It looks like the holes in the outer sphere were created with booleans, or possibly with a plugin called Edge Extrude Pro which lets you cut holes with splines.
  • Jack Sewell
    August 8, 2010 at 9:30 pm
    Great! Will check out both of those, thanks for sharing 🙂
  • Jack Sewell
    August 8, 2010 at 9:34 pm
    Is Edge Extrude Pro compatible with 11.5?….
  • Adam Trachtenberg
    August 8, 2010 at 11:39 pm
    Yes, the plugin works fine in 11.5.
  • Jack Sewell
    August 9, 2010 at 7:36 am
    Many thanks Adam…..
