  • Posted by Outis on June 5, 2005 at 9:50 pm
    I needed to spee d up some footage about 175% and I was wondering if anyone out there had a better plug in or program to achieve this other than fcp hd, such as for after effects. When I do it in fcp, it looks a bit choppy and has some horizontal lines.
    Thank you
    Aren Hansen replied 21 years, 2 months ago 3 Members · 2 Replies
  • Gunner Jones
    June 5, 2005 at 9:54 pm
    Check out Twixtor or re:Timer plug ins.
    If FCP doesn’t look right, it often means that you may not have rendered it at Full Quality, are not in SafeRT or that you are not monitoring the effect on a video monitor. Make sure you are doing the above. In FCP 5, speed effects look quite good.
  • Aren Hansen
    June 6, 2005 at 6:26 am
    Try turning off frame blending.
