Activity Forums VEGAS Pro speeding up video – only 4 times?
  • speeding up video – only 4 times?
    Posted by Csaba Nemes on October 17, 2008 at 12:44 pm
    Hi!
    I have just started to use Sony Vegas, and i have a problem:
    When i speed up a video clip, tha maximum rate is 4 times faster than the original. Is there a possibility to reach a faster rate? For example in PremierePro i think tha max is 1000.
    Waszil
    Mike Kujbida replied 17 years, 10 months ago 5 Members · 5 Replies
  • Enrique Orozco
    October 17, 2008 at 3:33 pm
    1.- apply maximum speed to clip and render to AVI
    2.- put your “speedy” AVI on Vegas and apply required speed again …..
    3.- re-render to AVI, and so on ….
  • Terry Esslinger
    October 17, 2008 at 4:27 pm
    I believe you can go 12x by using a combination of Ctrl stretching and velocity envelope. Thats 1200%
  • Csaba Nemes
    October 17, 2008 at 4:31 pm
    yes, that is the method i wanted to avoid. It is kind of hacking, and not too flexible…
  • Joe Mantaratz
    October 17, 2008 at 11:40 pm
    I used to do the same thing with rendering over and over again. You can hold down the ctrl key while clicking and dragging the right edge of the clip. If you stretch it, it will play slower and shortening will play faster. You will see a saw tooth wave drawn on the clip to indicate that it’s time has been changed. Hope this helps.
    John
  • Mike Kujbida
    October 17, 2008 at 11:43 pm
    Terry is correct.
    To make it even faster, render it, bring it back in again and repeat.
    Or buy Veggie ToolKit for a plug-in called Time Bandit which allows speeds much faster than Vegas is capable of.
