Activity › Forums › Adobe After Effects › Speeding up preview / scrubbing frames – very current system
  • Speeding up preview / scrubbing frames – very current system
    Posted by Rich Vogel on March 24, 2012 at 3:24 am
    Hello, I just built a new system and have a few questions.
    I have After Effects CS5 64-bit, and am experiencing lag scrubbing frames and previewing clips. I’m looking for any tips to speed things up, to make previewing and editing a bit faster. I am somewhat new to this and could use some pointers. Thanks.
    Here’s my system:
    Intel Core i7-3930k
    Asus P9X79 Pro
    EVGA GeForce GTX 570
    G Skill Ripjaws Z Series 16gb
    Crucial M4 256gb SSD (os drive)
    (2) Seagate 3TB SATA III 7200 6.0 Gb/s drives
    John Cuevas replied 14 years, 6 months ago 2 Members · 1 Reply
  • John Cuevas
    March 24, 2012 at 12:44 pm
    AE isnt an editor, so I hope you really aren’t editing much in AE, cause it will just frustrate you. As far as previewing goes, the only realtime preview in AE is the RAM preview and the duration of that is determined by the amount of RAM you have and the size of the clip(1920×1080, 720×486). To perform a RAM p-preview, select your preview area with “B”(beginning), “N”(end) and press zero on the number keypad. You will see a green line move across the comp as AE caches your frames and it will play when it’s done.
    Couple of links you should check out:
    Preview video and audio
    Getting started with After Effects (CS4, CS5, & CS5.5)
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
