Activity Forums VEGAS Pro Speeding up event for certain look
  • Speeding up event for certain look
    Posted by Ron Whitaker on November 3, 2013 at 9:02 pm
    Is there a way in Vegas 12 to speed up an event on the timeline so much that it almost looks like individual frames put together?
    I’d like to get that look for transitions in commercial work. All I’ve found is the Playback Rate in the event properties, but that only allows you to go up to 4.000, which is fast, but not fast enough for what I’m looking for.
    Ron Whitaker replied 12 years, 10 months ago 2 Members · 3 Replies
  • John Rofrano
    November 3, 2013 at 9:14 pm
    [Ron Whitaker] “I’d like to get that look for transitions in commercial work. All I’ve found is the Playback Rate in the event properties, but that only allows you to go up to 4.000, which is fast, but not fast enough for what I’m looking for.”
    You could use VASST TimeWarp ($9.95). It will increase the speed up to 10,000 times normal rate.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ron Whitaker
    November 3, 2013 at 11:06 pm
    Excellent! I’ll get it and give it a try!
    I’ve purchased others like Stutterframe and think they’re great!
  • Ron Whitaker
    November 3, 2013 at 11:34 pm
    I downloaded TimeWarp.
    All I get are “Catastrophic failure” errors whenever I try to timewarp an event.
    Here are the details:
    Microsoft Windows NT 6.1.7601 Service Pack 1
    Version 12.0 (Build 710) 64-bit
    TimeWarp Version: 1.0.2.29603
    Message: Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
    From: Void AddImageSequence(System.String, Int32, Double, Boolean, UInt32 ByRef, Sony.Vegas.MetaPathType ByRef)
    at Sony.Vegas.IMediaCOM.AddImageSequence(String path, Int32 frameCount, Double fps, Boolean addToProperBin, UInt32& mediaID, MetaPathType& metaPathType)
    at Sony.Vegas.MediaPool.AddImageSequence(String path, Int32 imageCount, Double fps, Boolean addToSelectedBin)
    at Sony.Vegas.MediaPool.AddImageSequence(String path, Int32 imageCount, Double fps)
    at VASST.Scripts.x674cdd4a1241e147.xfbaa81d69f94328b(VideoEvent xeaca0c3bf6ecc4e3, Double xd01e8fe10a047429)
    at VASST.Scripts.x674cdd4a1241e147.xd274b7a9f6531ce8()
    at VASST.x4cc7ca5b706ef360.x031e468258c5689f(Object x816e7dd1e316ed77, EventArgs x9ab41157d14bf1b6)
