Activity › Forums › DaVinci Resolve › speeding up accordingly
  • speeding up accordingly
    Posted by Alex Gat on May 14, 2022 at 8:31 am
    This is something I don’t know how to do precisely, I always fiddle around but maybe there is a quick solution for it.
    Let’s say I have a 60s long clip. I want to make an edit 30s long with it.
    I want to start with a normal speed for the 10 first seconds of the clip and to end with a normal speed with the last 10 seconds of if.
    So the middle part will be sped up, but by how much? Is there an easy way to either calculate it (I think I could find the algorithm) or to do it, a function maybe?
    Thanks a bunch.
    Alex
    Glenn Sakatch replied 4 years, 4 months ago 3 Members · 3 Replies
  • Glenn Sakatch
    May 14, 2022 at 2:47 pm
    its fairly basic math.
    60 second clip – 20 seconds (first and last 10 seconds) = 40 second clip.
    How fast does a 40 second clip have to run to fit into a 10 second hole?
    I’m guessing around 4x faster than normal.
  • Mohammed El Sharqawy
    May 15, 2022 at 2:01 am
    Hi Alex,
    Result Time/Original time * 100 = speed percentage
    for your case it 10/40*100=25%
    Hope this solves your problem.
    have a good day!
    Mo
  • Glenn Sakatch
    May 21, 2022 at 11:04 pm
    Sorry Mohammed, but your result is confusing.
    Are you saying the OP should run his footage at 25 percent speed to have the clip fit into the hole? That isn’t going to work.
    Again, its pretty simple “Editor Math” as shown above.
