Activity › Forums › Adobe After Effects Expressions › Speeding up a process via scripting
Posted by Gary Noden on April 11, 2012 at 1:14 pmHi there,
I was wondering if any scripting guru out there could help me out.
I want to make a script that will speed up a process of attaching paint clones to tracking attach points, to help clean up reference markers off a character’s face. I’m doing it a lot!
I know what I want to accomplish, but just have no idea what the scripting syntax would be. I am used to creating intermediate level Maya mel scripts, but am a bit at sea with scripting in After Effects
All help gratefully received.
Gary Noden replied 14 years, 5 months ago 2 Members · 6 Replies -
Dan Ebberts
April 12, 2012 at 1:57 pmThe key to scripting something like this is describing your workflow in a way that can be converted to an algorithm that can be scripted. For example, how will the script know which paint clones get attached to which tracking points?
Dan
Gary Noden
April 12, 2012 at 2:12 pmWell, in every instance there are four tracked points that need removing on the character’s face so I’m using an expression which makes clone1’s clone position come from tracker1 trackpoint1 plus its offset and the clone’s position comes from tracker1 trackpoint1
The expression for clone1’s position is:
motionTracker(“Tracker 1”) (“Track Point 1”).attachPointThe one for the clone source is similar with:
+ motionTracker(“Tracker 1”) (“Track Point 1”).attachPointOffseton the end so I can twiddle the source of the clone to not be the dot I am removing.
I just want a quick way to create and link up the clone’s to the tracking points via a script, as I have so many to do.
motionTracker("Tracker 1") ("Track Point 1").attachPoint
+ motionTracker("Tracker 1") ("Track Point 1").attachPointOffset -
Dan Ebberts
April 12, 2012 at 2:48 pmI don’t know if it helps, but if there is a one-to-one relationship, you could use the same expression for each clone, calculating the name of the appropriate tracker from the name of the clone brush, like this:
n = thisProperty.propertyGroup(2).name.split(” “)[1];
motionTracker(“Tracker 1”) (“Track Point ” + n).attachPointCreating a script that would go through and attach all the clones to corresponding tracking points via expressions wouldn’t be hard to do, just a little time consuming to set up.
Dan
Gary Noden
April 12, 2012 at 3:49 pmYep, JavaScript is still very new, if not non-existent. 🙂
Is there a way in After Effects to see code in action as you perform a function like you can with Mel script in Maya?
I think I’m going to sit down with the scripting stuff from Adobe and start with it’s equivalent to “Hello World”
Thanks so far, Dan. It’s much appreciated.
n = thisProperty.propertyGroup(2).name.split(" ")[1];
motionTracker("Tracker " +n) ("Track Point 1").attachPoint -
Dan Ebberts
April 12, 2012 at 4:11 pmNo, unfortunately there isn’t anything like that in AE. The best you can do is develop/test your code in the ExtendScript editor where you can set breakpoints and examine your variables.
// Hello World:
alert(“Hello World”);
Dan
Gary Noden
April 15, 2012 at 8:16 amlol
Yep, gotten that far now.
Actually, I’m getting the hang of it thanks to your website!
You’re a clever guy
So, I’ve got the undoGroup, the check for a layer being selected, I can add a paint effect to the layer, but I don’t know how to add a clone stroke.
I’ll get there.
Thanks again for your time.
