Activity Forums Adobe Premiere Pro Speedgrade looks appear wrong (too bright) in Premiere
  • Speedgrade looks appear wrong (too bright) in Premiere
    Posted by Jonathan Graves on October 6, 2013 at 1:56 am
    Hi guys,
    I’m trying to use Speedgrade to create looks and bring them into Premiere. For the most part this has been working perfectly, but I’ve been having problems with Speedgrade looks opening up much lighter in Premiere than they should be. As far as I can tell, nothing has changed in my workflow or formats from when the looks transfer correctly and incorrectly. Here’s a sample of what I’m seeing.
    Any ideas?
    Jonathan Graves replied 12 years, 11 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    October 6, 2013 at 5:47 am
    Do the non-graded pieces of material in each program look the same in each program? I ask because I wonder if you’re using some kind of project “calibration LUT” or a video format that Speedgrade may, through many reasons, display differently by default than Premiere.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Jonathan Graves
    October 6, 2013 at 3:28 pm
    Thanks for the reply Angelo.
    Now that I think of it, the footage I’m working with is an “MPEG-2” format that Speedgrade doesn’t display, so I’ve been rendering bits to MOV files and making my Speedgrade looks from those.
    I would chalk it up to this, but what’s strange is the issue seems to come and go, and even when it happens, it’s only on some clips. Right now all looks are displaying the same, even though the problem remained through a couple re-starts.
    My hardware (MBP) is almost brand new, so I doubt that’s part of the problem.
    Someone posted about this to the Adobe forums in July as well, but didn’t get any responses.
    Hoping for smooth sailing when the direct Speedgrade-Premiere integration arrives on 10/15.
