Activity › Forums › Adobe Creative Cloud › SpeedGrade 2015 keyframe issue
  • SpeedGrade 2015 keyframe issue
    Posted by Aaron Soileau on October 20, 2023 at 1:34 am
    Hi there. Not sure if anyone here is still using SpeedGrade, but I recently downloaded it from an old download link I found on the web that I guess Adobe hasn’t tracked down yet. While installing, it said a license was found when I signed in with my current CC account, and it installed normally. It also shows up in the Creative Cloud app as CC 2015, so everything is installed properly – no cracks were used. I’m having a seemingly bug related issue with keyframing, however. As soon as I set a keyframe the video is completely destroyed from that frame to the end of the video. Before that frame however, there is no damage. I’ve attactched some images to demonstrate. I’m using CC 2015 9.0 so I’m not sure if this is something that was fixed in 9.0.1 or 9.1. I can’t find any download links for the 9.0.1 patch, but I did find one for 9.1. However SpeedGrade wouldn’t launcg past the splash screen after installing, so I had to reinstall 9.0. Just wandering if anyone is still familiar with this software and/or has experienced this issue before. It’s a really great piece of software that I’d like to continue to use as you have significantly more control over the image than with Lumetri.
    Hector Vera replied 2 years, 5 months ago 2 Members · 1 Reply
  • Hector Vera
    April 10, 2024 at 8:27 pm
    Never have used this program before but in my experience with other older versions of an application like this, they usually do not provide a legit way to upgrade from an old outdated version to a new one directly and if so, it may have some glitch and bugs from old outdated files that could be preventing it from working like it should. Usually in this case, I would just find the latest version of this application from an official source and install it that way so its a lot more likely to have all the features working. You can also try uninstalling and reinstalling the application if something is broken cause it could be a broken .dll file or some files needed to run features of an application in general. Good luck! 🙂
