Activity › Forums › Adobe Premiere Pro › Speed up HDV rendering in CS3/Win?
  • Speed up HDV rendering in CS3/Win?
    Posted by Lucian Smith on September 16, 2007 at 5:02 pm
    I need to edit some HDV footage with Adobe Premiere Pro CS3, but have discovered to my dismay that my laptop is not up to the task. Is there a way to convert the footage to standard definition or even lower quality, edit it, and then replace the low quality footage with HDV?
    Mango
    Aanarav Sareen replied 19 years ago 3 Members · 3 Replies
  • Blast1
    September 16, 2007 at 6:16 pm
    You didn’t mention what the speed of your laptop was, If its fast enough you maybe able to use a intermediate codec like Cineform, which might be better than offlining and matching GOP cuts.
  • Lucian Smith
    September 17, 2007 at 4:24 pm
    Hey Blast1, thanks for your reply.
    The laptop has a Pentium M 1.86Ghz with 2GB of RAM – perfectly adequate for a 3-camera shoot in standard definition, but it can’t even play a single HDV shot.
    I did some more experimenting. I rendered a minute of HDV footage to lower quality. I placed it into an HDV sequence and discovered that it would still only play at a few frames per second – with no effects, transitions, or anything. However, in the program monitor, it would play perfectly. I tried MPEG2 and H.264 with identical results.
  • Aanarav Sareen
    September 17, 2007 at 7:41 pm
    I would recommend downloading a trial version of Cineform Aspect HD and see if that helps.
    – Aanarav
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
