Activity › Forums › Apple Final Cut Pro Legacy › Speed up Compressor?
  • Speed up Compressor?
    Posted by Leonard Frankford on March 8, 2011 at 7:01 pm
    Is there any way to speed up Compressor? I am trying to convert several 30-45 minute files output as Quicktime movies straight out of Final Cut into mpg2 files. Compressor just sits there for more than an hour before it starts to do anything. I ran a batch overnight and it only did three files out of seven, one of which was only 10 minutes long. I have closed FCP and all other programs. I have a G5. Any suggestions? Thanks.
    Leonard F.
    Keith Mcgregor replied 15 years, 6 months ago 4 Members · 4 Replies
  • David Roth weiss
    March 8, 2011 at 7:20 pm
    Export a self contained QT of each seq. first (that’s very fast), then use those in Compressor. The way you’re doing it now unnecessarily re-renders everything before encoding in Compressor, taking significantly more time.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Leonard Frankford
    March 8, 2011 at 7:30 pm
    So self-contained is the way to go. I was making reference clips. I’m remaking them now and I’ll see how it goes. Thanks.
    Leonard
    Leonard F.
  • Paul Jay
    March 8, 2011 at 7:37 pm
    Buy Any Mac Mini Intel will help 😛
    G5 Speeds are ancient indeed.
  • Keith Mcgregor
    March 8, 2011 at 8:03 pm
    Have you set up compressor to it’s best? Are you running a dual core power mac G5? I had a dual 2.3? and it utilized almost all of my processing power each time. If you can, get an octo processor power mac and set it as your cluster. See this: file:///Users/instructor/Documents/Info/KMC%20Infor/Using%20Compressor%20with%20multiple%20cores%20-%20Digital%20Rebellion%20Blog.webarchive
    and always remember, it’s not always the computer’s fault, it still depends on the format (from and too), the drives (firewire, usb, internal) and of course size and length. I have had a gigantic leap in performance adjusting the settings in Qmaster or adding another machine to the cluster. Sometimes it’s just a finesse thing.
    Reality? What did you make it?
