Activity Forums Adobe Premiere Pro speed-up – building up to 1 frame edits
  • speed-up – building up to 1 frame edits
    Posted by Nils Palmen on May 21, 2005 at 4:38 pm
    hi,
    i want to make some sort of montage were there is a building up in the speed. so you start of with let’s say a rithm (sp?) of 25 frames and you end 30 seconds later with 1 frame rithm.
    as i see it there are two possibilities …
    1 make a montage with all cuts with same frames and gradually speed it up – but this will also speed up the images.
    2 make a montage where you cut down the number of frames per ? … but than it will be building up in a “stairway” and not a gradual curve …
    what is the best way or what am i missing here in my approaches?
    tnx nils
    Steven L. gotz replied 21 years, 3 months ago 2 Members · 1 Reply
  • Steven L. gotz
    May 21, 2005 at 6:06 pm
    The “stairway” (great description) method is all you can do in Premiere Pro. In After Effects you have Time Remapping to do it properly.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
