Activity Forums VEGAS Pro Speed up 2 tracks
  • Speed up 2 tracks
    Posted by Pryito on June 26, 2007 at 6:24 pm
    I have a 9 minute video, which is currently 4 tracks. Track 1 is text, track 2 is the video with a mask for a guassian blur, track 3 has the guassian blur, and track 4 is audio. I would like to speed up tracks 2 and 3 to fit into an 8 minute segment. Can someone give me some suggestions? Many thanks in advance!
    Pryito replied 19 years, 2 months ago 3 Members · 4 Replies
  • Gary Kleiner
    June 26, 2007 at 6:34 pm
    Hover your mouse pointer over the right edge of the event on track 2 then hold the ctrl key while you drag it left. This compresses (speeds up) the event.
    Do the same to track 3 to match.
    If the tracks are made up of multiple events, first select them all and hit G to group them.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Terry Esslinger
    June 26, 2007 at 9:34 pm
    You understand that if you do this (as per Garys instructions) your video will be speeded up (run in a slightly fast forward mode). Also the text events will not line up as they did before and the sound will not be synched with the video. This may not be important, depending on the content.
  • Pryito
    June 26, 2007 at 9:42 pm
    Yes, its a world of warcraft video, caught with fraps, no audio, and overdubbed music. So, I am aware. Thanks! 🙂
  • Pryito
    Perfect sir, you are a lifesaver, yet again! Thanks!
