Activity Forums Blackmagic Design speed test
  • speed test
    Posted by Phil Harbath on February 15, 2007 at 5:40 pm
    I am wondering, should the speed test give pretty much the same results whether the drive is full or not. I have a set of SATA drives that is now returning relatively slow speed results and i am trying to isolate the problem.
    thanks
    Phil
    Phil Harbath replied 19 years, 7 months ago 2 Members · 2 Replies
  • Kristian Lam
    February 15, 2007 at 11:05 pm
    The Disk Speed Test will report the current throughput of the drive so if the drive is almost full, you’ll find that the speed reported back will be lower than when it is empty. This is normal as SATA drives will slow down as the space gets used up.
    regards
    Kristian Lam
    Blackmagic Design
  • Phil Harbath
    February 16, 2007 at 12:01 am
    thanks for the info, that helps alot.
    phil
