Activity Forums Blackmagic Design Speed Test and Raid or no Raid considerations.
  • Speed Test and Raid or no Raid considerations.
    Posted by Steve Lim on May 16, 2005 at 6:50 am
    Hi all,
    We have a new G5 with 2 400GB drives installed _internally_. I initially decided to raid stripe them together into one big 800GB volume. I ASSUMED that raid would be a good idea. Now I’m hearing from people that it is a BAD idea to combine your data with the same drive that your OS runs from. Is this true?
    I have 2 options
    1. 2 Internal 400GB in raid as one 800GB Volume (OS and Data share the same volume)
    2. 2 Internal 400GB as seperate volumes 1 * 400GB for the OS and 1* 400GB for the data.
    Which setup is faster? Or safer?
    Secondly my speed test has come up with the following benchmarks.
    Disk Read 87.0 MB/s
    Disk Write 108.1 MB/s
    Is this fast enough for SD? We would like to capture and output to betaSP and DV.
    Kaspar Kallas replied 21 years, 4 months ago 3 Members · 3 Replies
  • Kaspar Kallas
    May 16, 2005 at 7:11 am
    this why it is a badi idea: if one of the disks fails you loose data on both.
    this is why it is a good idea: you get more than on stream of uncompressed SD @ 10 bit
    my recomandation would be to get yourself an external FW drive for yer system and project fails – so when something happens with yer external raid then you would only loose the media that you can recapture
    if you are willing to spend a bit more than you could get yer self a swift data 200 (https://www.transintl.com/store/category.cfm?Category=2490) with the sonnet option then you would be able to add 3 extra drives to yer system so all three drives could be internal and you would have 2 slots for upgrade
    I use my self the latest version – very happy with this, I have 4 drive raid0 and a system drive all inside my mac, I get @ empty drives 210+MB/s rw
    -Kaspar
  • Markh
    May 17, 2005 at 1:15 am
    >”this is why it is a good idea: you get more than on stream of uncompressed SD @ 10 bit”
    Are you suggesting a 2x400GB RAID 0 is enough for two streams of uncompressed SD at 10-bit?
    -m
  • Kaspar Kallas
    May 17, 2005 at 6:38 am
    for sure SD pal @ 10 bit is 22.1MB/s
    and SD ntcs @ 10 bit is 23.1MB/s
    single sata drive should not go lower than 30MB/s on inner circles of the disk – when empty you should expect 55MB/s and stripeset almost doubles the preformance
    -Kaspar
