Activity Forums Avid Media Composer Speed FX on Nitris DX not working
  • Speed FX on Nitris DX not working
    Posted by Michael Brown on February 10, 2011 at 4:28 pm
    Running MC Nitris DX v 5.0.3, Win 7/64.
    Footage is 1080i/29.97, DNxHD 145
    I’m not able to apply a “fit-to-fill” speed effect… nothing happens.
    So, let’s try a timewarp. “Effect does not apply.”
    How about just a freeze frame? The choice is grayed out on the menu.
    I’ve done all these effects many times, but only on SD material. Is there a limitation on HD footage or is my Avid broken?
    Thanks for any advice.
    Mike Brown
    Video/Film Producer
    American Heart Association
    Michael Brown replied 15 years, 6 months ago 2 Members · 2 Replies
  • Job Ter burg
    February 10, 2011 at 11:04 pm
    Sounds like you are mixing & matching frame rates. Your source footage then has a Motion Adapter applied to it, which won’t allow you to add a motion effect or timewarp. However, if you splice the shot into the timeline, then open the Motion Adapter (effects mode), you can promote the motion adapter to a Timewarp, and set speeds as you like.
    That said, you don’t seem to be consciously working in a different framerate from your source footage, so that is something to make sure.
  • Michael Brown
    February 11, 2011 at 1:14 pm
    Well, that was it! I had 1080i footage in a 720p sequence. I changed the project settings, did a “refresh sequence” and it seems to be working! Many thanks, Job.
    Mike
