Activity Forums Avid Media Composer speed effect
  • speed effect
    Posted by Tel Jaba on December 14, 2010 at 9:43 am
    hey guys
    how do you create the effect that is used a lot in music videos or sometime even CSI where the shot is in normal speed, then it speeds up for a few frames, flashes and then jump to another clip or back continues the same shot
    how many frames is the speed? how long is the flash and how is it created? in brightness effect? or dissolve to a white solid color?
    Grinner Hester replied 15 years, 9 months ago 2 Members · 1 Reply
  • Grinner Hester
    December 19, 2010 at 4:03 pm
    I use sppedramp and sapphire glows. I adhere to no template. It depends on the footage and the vibe. You can also just match frame motion clips.
