Activity › Forums › Adobe Premiere Pro › Speed / Duration
Speed / Duration
Posted by Simon Roughan on July 24, 2013 at 3:52 pmHi Everybody,
I have a clip that I have changed by “Reverse Speed 200%” in the clip speed/duration dialog box. Even after rendering, the clip stutters in my Video Monitor, although it looks good on the computer.
It is AVC-Intra 100 HD material in Premiere CC. Can anyone tell me what Im doing wrong?thanks in advance
SimonYou know I’m born to lose, and gambling is for fools, but that’s the way I like it, baby. I don’t want to live forever!
Simon Roughan replied 13 years, 2 months ago 4 Members · 10 Replies -
Ivan Myles
July 24, 2013 at 4:36 pmIn order to separate Speed/Duration from other potential causes, please confirm whether the video monitor can play AVC-Intra clips at normal speed.
Also, how is the AVC-I clip being played: from Premiere Pro on a secondary full screen display (Edit>Preferences>Playback>Video Device), with a media player outside of Premiere Pro, other?
Simon Roughan
July 24, 2013 at 5:22 pmHi Ivan,
thanks for the quick reply. The signal runs out through a Blackmagic Intensity Pro card. The rest of the AV-Intra clips in the sequence play ok. Lots of other clips have speed / duration changes too, although the one that stutters is the only one with a reverse.mfg
Ivan Myles
July 24, 2013 at 5:28 pmIs the clip being played by Premiere Pro or as an encoded file in a media player?
If Premiere Pro, is the video monitor set up as a full screen display using Edit>Preferences>Playback>Video Device?
Also, have you tried rendering a preview? Premiere might just be coughing up when trying to play in real-time.
Peter Garaway
July 24, 2013 at 5:39 pmHi Simon,
Do you have CUDA or OpenCL enabled? If so, can you try turing it off to see if that resolves it?
Peter Garaway
Adobe
Premiere Pro -
Simon Roughan
July 24, 2013 at 5:46 pmIm not at work anymore, but the clips are from a P2 card (copied first onto a hard drive), and imported straight out of the media browser into the project, so theyre not being played by a media player. (If I understand you correctly).
Yes, the HD monitor is full screen.
I have only rendered the sequence so far. I havnt tried exporting it yet. Normally I do all the finishing in AE, but liked the look of one of the cinema filters in Premiere, so wanted to master it there. I will try to export it tomorrow. Like I said, its strange because the rest of the sequence plays fine. And my workstation is an x820, 64 gigs ram and a nvidia maximus setup, so there should be no problems there.You know I’m born to lose, and gambling is for fools, but that’s the way I like it, baby. I don’t want to live forever!
Peter Garaway
July 24, 2013 at 5:56 pmTry 1 of the following 2 solutions to see if it helps.
1. Disable CUDA
2. Right-click the clip in the Timeline, select Field Options> Check Reverse Field Dominance box
Peter Garaway
Adobe
Premiere Pro -
Chris Borjis
July 24, 2013 at 10:52 pmI was just going to suggest reversing fields on that as well.
Simon Roughan
July 25, 2013 at 9:53 amHi Peter, thanks for the tip. I turned off the CUDA, and now it plays smoothly, although it naturally takes 4 times longer to render.
Any ideas why the speed / duration change doesn’t function properly with the acceleration turned on?mfg
Peter Garaway
July 25, 2013 at 4:29 pmHi Simon,
It’s a known issue and will be addressed, but I don’t have an ETA on that.
Try keeping CUDA on and reverse the field dominance. That should also resolve the issue.
Take care,
Peter Garaway
Adobe
Premiere Pro -
Simon Roughan
July 26, 2013 at 8:05 amI tried that, but to no avail…
