Activity › Forums › Apple Final Cut Pro Legacy › speed changes on Canon 5D 1920×1080 24p footage, using FCP7
  • speed changes on Canon 5D 1920×1080 24p footage, using FCP7
    Posted by Kyle Schneider on January 22, 2015 at 8:10 pm
    Hello all,
    So, I have 1920×1080 24p footage from a Canon 5D that I’ve converted to Apple ProRes 422. I’m trying to speed it up in FCP7, but it never comes out clean. If I mark “frame blending” it makes it look soft & a little blurry, like there’s multiple images overlapping, and If I don’t mark “frame blending” it’s glitchy and choppy. I don’t have this issue with any other footage.
    Is there a secret or better technique for speeding up this footage? Or does the 23.98 frame rate just have issues with speed changes? Gopro 23.98 footage has no problem with speed changes.
    I appreciate any info, thanks so much!
    Kyle Schneider replied 11 years, 7 months ago 1 Member · 3 Replies
  • Kyle Schneider
    January 26, 2015 at 7:39 am
    Okay, cool, that makes sense. So doubling the speed would put the frame rate at 47.96.
    But, say I’d want to speed a regular %100 clip up to %150. Would I just change the frame rate to 35.97? Or If I sped it up %30, would the frame rate be 31.174? Are all those frame rates stable?
    Thanks SO much for your help,
    Kyle
  • Kyle Schneider
    February 19, 2015 at 5:08 pm
    Okay, I’m confused. I have a couple more questions -Your help is invaluable!
    You said: “The same thing applies to conforming a 23.976 clip to 47.952 because it isn’t an integer multiple of the TIMELINE’S frame rate.”
    -So what is the timelines frame rate? Is it 23.976, 23.98, or 24?
  • Kyle Schneider
    February 19, 2015 at 9:34 pm
    The footage is 23.98 and the timeline is also 23.98
