Activity › Forums › Adobe Premiere Pro › Speed Change Shortcut?
  • Speed Change Shortcut?
    Posted by James Strecker on July 10, 2014 at 6:10 pm
    Hello. I’m fairly new to Premiere and am trying to slowly but surely figure out some hotkey shortcuts to make my life easier. I have used Sony Vegas for the past 8 years and made the switch to Premiere because it was an easier workflow with After Effects.
    Here’s my issue. In Vegas, if I wanted to change the speed of a clip, I would hold down Ctrl and drag the end of a clip in whatever direction, speeding it up or slowing it down, and I could actually see the length I was changing it to, line it up precisely with markers, etc.
    In Premiere, it seems the only way to change the speed is to right-click and go to the Speed/Duration setting, then enter a percentage. This is fine, except that I am constantly going, “120%? No. Ok. *Go back* 130%? No. Ok. *Go back* 131%?” etc. etc. etc. It is very annoying.
    Basically, I would like to know if there is a Vegas-like shortcut to this, so I don’t waste half of my editing time getting one clip to the right speed.
    James Strecker
    JTS Entertainment
    https://www.youtube.com/JTSEntertainment
    James Strecker replied 12 years, 2 months ago 2 Members · 2 Replies
  • Jp Pelc
    July 10, 2014 at 6:26 pm
    Yes, in the tools palette you’ll find the rate stretch tool which should do exactly what you’re looking for. I added “R” as a shortcut to activate it as I find it very convenient
  • James Strecker
    July 10, 2014 at 6:29 pm
    You, sir, are a god. Thank you so much.
    James Strecker
    JTS Entertainment
