Speed change quality
I have a segment of a sequence that I have to slow down, the sequence contains some multiclips. To avoid the hassle of reducing the speed on the individual clips, I want to nest them and reduce the speed on the nested sequence.
Will I loose quality doing the speed change on a nested sequence as opposed to individually and will the frames blend as well?Thanks,
CG
