Activity Forums Apple Motion Speed change export problems
  • Speed change export problems
    Posted by Andrew Gregg on April 15, 2009 at 3:00 pm
    I recently applied some speed changes to a clip in motion. It was shot at 60 fps in a 24fps base, so as to give slow motion. The clip starts at 250% (normal speed), slows to 100% (slow motion), and then speeds back uo to 250% (normal speed).
    While the clip runs fine within motion, the exported film stutters at the speed change, and then becomes a still fame.
    Does anyone know why this is happening?
    Andrew Gregg
    Director
    LiveABC Taiwan
    Andrew Gregg replied 17 years, 5 months ago 1 Member · 1 Reply
  • Andrew Gregg
    April 15, 2009 at 3:58 pm
    Well, I tried exporting in XD CAM EX 720p 24 VBR Movie and there’s no problem now. I was exporting using “current settings.”
    The thing is, I sent the clip from Final Cut directly. The timeline settings are the same (XD CAM EX 720p 24) in that project. Where do you think the problem comes from?
    Andrew Gregg
    Director
    LiveABC Taiwan
