Activity Forums Apple Motion Speed Change
  • Speed Change
    Posted by Juan Obregon on January 26, 2006 at 5:33 pm
    Hi to all
    Can someone please tell me how do I chage the speed of an object? In after effects I just change the duration and it slows down the footage. How do I do it in Motion?
    Matzunaga
    Juan Obregon replied 20 years, 7 months ago 3 Members · 5 Replies
  • Arnie Schlissel
    January 26, 2006 at 7:28 pm
    It’s a little counter-intuitive. OK, it’s a lot counter intuitive!
    In the timeline, right click (option click if you have a 1 button mouse) on the object & select “Reveal Source Media”. this will open a new window out from under your canvas that shows all of the media files that are in the timeline. Select the one you want to change the speed of, then change the speed in the inspector.
    Arnie
    https://www.arniepix.com
  • Juan Obregon
    January 26, 2006 at 8:24 pm
    I have been to the media tab in the inspector and it just wont work, tried different FPS it just wont work. Does it mean that I have to go back to AE?
    Matzunaga
  • Mark Spencer
    January 27, 2006 at 1:17 am
    Changing the Frame Rate parameter in the Media tab of the inspector should certainly work, but you can also try keyframing the Scrub filter – not intuitive either, but works pretty well.
    Mark
    Mark Spencer
    Freelance Editor/Producer
    Apple-certified instructor, Final Cut Pro and Motion
    Author, Motion Visual Quickstart Guide from Peachpit Press (coming soon)
    https://www.applemotion.net
  • Mark Spencer
    January 30, 2006 at 9:03 pm
  • Juan Obregon
    February 1, 2006 at 8:06 pm
    That tutorial is just what I needed. For some reaseon, changing the fps in the media tab is not working for me but I did try the scrub and it worked great.
    Matzunaga
