Activity › Forums › Apple Final Cut Pro Legacy › speed change
speed change
Posted by Klaus on December 1, 2005 at 3:03 amHow do you make a speed change to an individual clip in the timeline without affecting the position of the clips which follow?
Andy Mees replied 20 years, 9 months ago 4 Members · 6 Replies -
Jeremy Garchow
December 1, 2005 at 3:09 amCopy the clip to the end of the timeline and perform the speed change there and then reedit it into the timeline. You’ll have to make up the time somewhere.
G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
ATTO 42XS <> Huge Systems 4105 Fibre -
Klaus
December 1, 2005 at 3:14 amThat’s what I’m doing at the moment, but it seems quite inefficient. Especially when you are experimenting with different speed changes. Surely there must be a better way.
Jeremy Garchow
December 1, 2005 at 3:19 amOkay…put that clip on the upper most video track all by itself and lock all of the rest of the video and audio tracks and play with speeds all you want.
Jeremy
John Pale
December 1, 2005 at 5:58 amjust match frame the clip. change the speed in the viewer. edit in place.
Andy Mees
December 1, 2005 at 6:15 ambetter to Match Frame to Original (Command Option F) otherwise your masterclip retains your speed adjustment rather than just the particular timeline instance
