Speed and duration question?
Don’t know if I am doing something wrong but I figured I’d run this past the experts…
I have some DV footage shot at 16:9 on my Panasonic GS400 on the. The length of the clip that I’d like to modify speed on is about 53 seconds. Here is what I want to do:
Frames 1-87 normal speed
Frames 88-208 25 percent speed for slow mo effect
Frames 209-524 normal speed
Frames 525-1599 25 percent speed for slow mo effectI applied cuts to the master clip at the exact places and made 4 separate clips. I applied speed changes to #2 and #4. The issue that I am seeing is that when the 25% speed clips end and the normal ones start again it seems “jumpy” as if frames are skipped or dropped. What is the secret to making this look good and seamless?
