Activity Forums Adobe Premiere Pro speed adobe premiere cs3
  • speed adobe premiere cs3
    Posted by Sherry Purdom on July 15, 2010 at 10:24 pm
    we use adobe premiere cs3 in our tv production instruction….what command do i need to do to slow the speed duration down of ALL the photos on the time line….the file is 52 minutes long and I do not think I should have to go into each photo and change speed?
    Sherry Purdom
    Alan Lloyd replied 16 years, 2 months ago 3 Members · 3 Replies
  • Ann Bens
    July 16, 2010 at 10:31 pm
    Photo’s do not have speed just duration.
    You cannot change the duration of all at once just one at a time.
    Nest your sequence in another sequence and use the stretch tool to adjust the total duration of the seqeunce.
  • Sherry Purdom
    July 17, 2010 at 12:30 am
    thank you so much so i assume when you say nest you mean avi this and then start another time line and then use the rate stretch tool?
    again, thanks
    Sherry
  • Alan Lloyd
    July 20, 2010 at 2:31 pm
    What Ann is referring to is nesting the sequence of photos – not rendering it and then changing the speed. Create a new (second) sequence and place sequence #1 in that. Again, do not export it as an AVI. That will introduce some unpleasantness.
