Activity Forums Apple Final Cut Pro Legacy speed adjustment makes clip jumpy
  • speed adjustment makes clip jumpy
    Posted by Chrisusvi on April 11, 2005 at 2:54 pm
    I have a few clips that I tried to slow the speed, but when I got to the 80% level and lower mainly, it gets jumpy or jittery. The same would go for speeding it up. Some clips would jump and others wouldn’t.
    What could the problem be?
    Don Greening replied 21 years, 4 months ago 2 Members · 1 Reply
  • Don Greening
    April 11, 2005 at 3:21 pm
    The problem is the 2 interlaced fields in your video. Use the flicker filter within FCP. It can be set from mild to wild. Just experiment and see what setting works best for your particular slo-mo speed…….on a broadcast monitor. If you don’t have one just use a TV.
    – Don
