Activity Forums Adobe Premiere Pro Speech Transcript
  • Speech Transcript
    Posted by John Frey on January 12, 2010 at 7:49 pm
    When I first switched over to PPro CS4 as my primary NLE, I tested the speech-to-text function. It did do the audio file transcription and the text appeared in the metadata window under speech transcript. That is as far as the test went. Now I have a 53 minute video of a presentation along with a separate audio file that needs voice-to-text transcription. I am well aware of the limitations and level of accuracy of such programs, but I have to give it a shot anyway. I was able to get an XML file from the transcription but no text shows up in the Metadata window in the Speech Transcription panel. I had planned to attempt a cut and paste from the Transcription window into MS Word. Or, if I can get the XML file to convert to text in MS Word, then I can go that route, but no luck so far. I have also tried Soundbooth with the same results. Anyone?
    John D. Frey
    25 Year owner/operator of two California-based production studios.
    Digital West Video Productions of San Luis Obispo and Inland Images of Lake Elsinore
    Orly Nay replied 13 years, 6 months ago 4 Members · 5 Replies
  • Jon Barrie
    January 12, 2010 at 10:18 pm
    If you can see the metadata panel showing a selected clip’s transcript then you should be able to copy the metadata text section and paste it into a document.
    – Jon Barrie
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • John Frey
    January 13, 2010 at 2:59 am
    I opened an Audition session that used the audio only file for transcription, and the text showed up this time. However, the audio that the client supplied was really poor. Even with noise redux and volume changes, the speech-to-text accuracy was pretty bad. It was enough, however, for me to cut and paste into my scripting program to designate scene changes. Hopefully, Adobe will improve it’s accuracy.
    John D. Frey
  • Chris Elley
    January 25, 2010 at 9:00 pm
    I was having trouble getting the text to copy into Word. However, I found that it copied fine into Text Edit. From Text Edit, you can copy to Word.
    Chris Elley
    Electro-Fish Media Inc.
    Austin, Texas
    electro-fish.com
  • John Frey
    January 26, 2010 at 2:05 am
    Thanks Chris. I didn’t think of that and it does work. Too bad that Adobe has such a poor rate of accuracy. Maybe they will improve it with CS5.
    John D. Frey
  • Orly Nay
    February 6, 2013 at 7:14 pm
    In Premiere CS4, from Metadata, I’m trying to copy the text into MSWord,I see that you pasted into Text Edit, then from Text Edit you pasted into MSWord. My question is where do I find Text Edit?
