Activity Forums Adobe Premiere Pro speech analysis grayed out (files not “read only”)
  • speech analysis grayed out (files not “read only”)
    Posted by Jim Wright on June 1, 2011 at 11:30 pm
    I have the full Creative Suite 5 installed and licensed. I import and edit MTS files from Panasonic TM700 without difficulty. I double click a clip and put it in Source Monitor, but menu Clip > Analyze Content is grayed out and so is “Analyze” at the very bottom right of the Speech Analysis panel in Metalogging workspace. All the files have the read-only box unchecked. Must be something simple that I don’t know!!
    Ben Smith replied 13 years, 5 months ago 4 Members · 5 Replies
  • David Cabestany
    September 3, 2011 at 3:32 am
    Hey there,
    Did you find a solution to this issue? I’m having the same problem with an .aif file
    I’m on PPro CS5 on Mac.
    Best,
    D.
  • Jim Wright
    September 3, 2011 at 1:39 pm
    Nope – never solved the problem. Sure wish I had. I’ve been manually transcribing interviews.
    Jim
  • David Cabestany
    September 4, 2011 at 3:31 am
    Sorry to read that. I”ll post a solution, if I find one.
  • Matthew Hoecker
    April 2, 2012 at 10:12 pm
    Also searching for an answer to this. I have MTS files from a Panasonic Lumix GH2 and Analyze content is grayed out. I have full read right permissions on all the files, and all have had their audio transcoded.
  • Ben Smith
    March 22, 2013 at 5:42 pm
    Did you retain the original file structure with the .MTS files? I’m finding that Premiere 5.5 really prefers if you keep the file structure intact if you are using raw files. With converted QT files it has no issues.
