Activity Forums Adobe Premiere Pro Sped up audio doesn’t render in AME
  • Sped up audio doesn’t render in AME
    Posted by Duke Sweden on May 27, 2016 at 10:58 pm
    I was making another video and in one scene I had to speed up the dialog to fit. I used speed/duration and increased the speed to about 115%, and checked off the box to not affect the pitch. It plays back in Premiere Pro but when I encode the entire video with AME, that one scene is silent. I’m currently trying to encode it with Premiere Pro rather than AME but I don’t know yet if that will do the trick.
    Anyone else run into this problem?
    Duke Sweden replied 10 years, 3 months ago 2 Members · 2 Replies
  • Chris Borjis
    May 27, 2016 at 11:56 pm
    haven’t seen that, one possible work around if your against the wall on
    a deadline, mark in / out the section and export a wav. bring that in
    and mute the sped up one.
  • Duke Sweden
    May 28, 2016 at 12:56 am
    Thanks Chris. Turns out the faster workaround was to export with Premiere Pro. Luckily it was only a 34 second video. Seems to be a similar problem to AME repeating the last second of audio at the end of a sequence. They say they fixed that in cc 2016. Hopefully they can fix this bug with an update, although I doubt the situation comes up much.
    Thanks again.
