Activity › Forums › Apple Motion › Specs for a G5 to run Motion
Posted by Dwaynne on May 30, 2005 at 2:37 amHi guys –
I tried doing a search but couldnt egt a clear answer for what I want to find out. I need to but a G5 and start running Final Cut Studio, esp for Motion 2. What specs should I go for if I need to be running Motion and AE/Combustion? Will the specs quoted on Apple’s website for M2 be sufficient? I experience a lot of stress with my current PC system using Combustion, and intend to go Mac.
Dwaynne
Jerry Hofmann replied 21 years, 3 months ago 6 Members · 12 Replies -
Videomansf
May 30, 2005 at 7:28 amIf you have no interest in real tim, then anything that apple states will work.
If your expecting Real Time performance with motion, I have found this to be the MINIMUM (motion would like double this). (I have used G5 dual 2.0s and 2.5s with motion 1 and nothing compares to my current 2.7)
Dual 2.7 G5
4GB ram -8GB here-
ATI X800XT or NV 6800 GPU cards -I have a X800XT-
Very fast raid (around 200MB/s) SCSI, Fiber, or SATA -I have a Medea RTRx on atto-
10 bit Uncompressed capture card (decklink, aurora, AJA) -I have a Kona 2 and Io from AJA-
Broadcast monitor.I can CC and Key UC8bitHD in RT with a lower third or two. Exports take less than playtime. All with the system above, and I am buying a second too. Very impressive numbers.
VM
Dwaynne
May 30, 2005 at 2:29 pmvideomansf –
sounds good to me. i am particularly wary of the video card, since the options apple listed weren’t available thru the system i was configuring on macmall. which delivers better performance – the nvidia or the ati?
Richard Harrington
May 30, 2005 at 2:47 pmI got the newest ATI
Particulary happy as it allows for 3 PCi cards
a Kona HD card
A firewire card
and a Srial ATI Extrernal card -
Dave Sullivan
May 30, 2005 at 3:37 pmHi all,
I’m using a G5 dual 2.5ghz, with 1gig of RAM, (to be upgrade to 4gig on Tuesday) 9800 XT 256mb graphics card.
I’m using Motion 1, and apart from the normal crashes, all appears to work, without any problems. With 4gig of RAM things are bound to work a bit smoother.Dave
Richard Harrington
May 30, 2005 at 7:25 pmRadeon 800 XT I beleive
1 ADC
1 DVI (perfect for me)256mb VRAM
Richard Harrington
June 2, 2005 at 12:58 pmBought card as an upgrade from Chesapeake Systems in Blatimore
Dwaynne
June 2, 2005 at 2:07 pmhow does the ati 9650xt that comes default with the system hold up? i was reading up some stuff on barefeats.com and it seems horrific.
