Activity Forums Adobe After Effects Speckles on footage when Exporting a rendered Comp as AVI (DV-PAL) in AE6.5
  • Speckles on footage when Exporting a rendered Comp as AVI (DV-PAL) in AE6.5
    Posted by Serg Merci on December 8, 2005 at 8:28 am
    Hello fellow friends!
    I am working with standard DV-PAL 720*576 footage. I have shot my brother, dressed in black, against a green screen. I have tried to key the green out…using keylight from the “effects” menu. I can’t seem to get a good key to start with. I know it’s hard on DV-PAL footage…but I’m open to any recommendations to obtaining the best method.
    Furthermore, I am having a minor problem when I export my comp as an AVI (DV-PAL) footage with the settings set to BEST.
    What happens is that I get “speckles,” some coloured, showing all over the footage.
    Sadly, I’m not an expert with AE6.5 but can someone also tell me please how I should export my keyed out “green screen” footage to use in composites in other programmes… ie. a way to get a result in AE6.5 and then export it out so I can use it in my editing/compositing programme. (I use Liquid Edition 6.1 for my editing).
    Any help would be much appreciated as always…
    I thank you for taking the time to read this.
    Regards,
    Serg – Australia.
    Serg Merci replied 20 years, 9 months ago 5,398 Members · 1 Reply
  • Serg Merci
    December 9, 2005 at 1:25 am
    I thank you for your advice on keylight..
    But any ideas on the “export” options from after effects?
    In my thread I also wrote:
    “with AE6.5 but can someone also tell me please how I should export my keyed out “green screen” footage to use in composites in other programmes… ie. a way to get a result in AE6.5 and then export it out so I can use it in my editing/compositing programme. (I use Liquid Edition 6.1 for my editing).”
    Thanks heaps once again.
    Serg.
