Activity Forums Compression Techniques Specify frames to be extracted
  • Specify frames to be extracted
    Posted by Laurent Nguyen on July 12, 2011 at 2:39 pm
    Dear forum,
    I am looking for a way to extract specific frame numbers from a movie, of course using ffmpeg. For the moment, the only thing I have found that is close to what I need is the following:
    ffmpeg -i movie.mov -ss 00:00:20 -vframes 33 im%5d.png
    With this command, I’m extracting 33 frames, with the first one starting at 00:20 seconds. However, I would like to specify the starting frame not by time but by frame number. In other words, I want to extract, say from frame #167 to #192 from my movie.
    Is there a simple way of doing this ? A virtual beer for the one who finds the answer.
    Laurent
    Michael Rampe replied 15 years, 1 month ago 2 Members · 1 Reply
  • Michael Rampe
    July 12, 2011 at 11:59 pm
    [Laurent Nguyen] “However, I would like to specify the starting frame not by time but by frame number.”
    This function only accepts time as an input. It does however accept a decimal:
    `-ss position’
    Seek to given time position in seconds. hh:mm:ss[.xxx] syntax is also supported.
    So…. If you know your frame rate, you can calculate the right time to start.
    Frame 167 in a 25 fps stream = 167/25 = 6.68 seconds.
    Thus your command would be:
    -ss 00:00:06.68
    Michael
